Can two people sleep east to west on 2 sections of the regular MOAB?Right about Horizontal L- track. We love the flexibility of the MOAB 3- section bed and have two 4" HD foam for foundations. When using N-S nonneed to go over rails. When using onlyb2 sections we have 4" pieces we shove between the pocketed wall and metal bed frame.
Here's a home-built prototype for a bed platform - material costs ~$40. Designed to work with Exped inflatable mats - single 21 x 72, double 42 x 72.
It works suspended by straps - four is sufficient. Experimenting with strap configurations, somewhat inspired by tensegrity. With more tensioning straps, travel over rough roads is bomber - no rattles or banging. Also experimenting with the side rails - putting the bed platform east-west on the rails, etc. Strap suspension makes it easy to level out the bed on uneven ground.Curious - are there just the five straps holding the platform up?
Post photos!We went with hammocks
The orange material is steel braces provided by Adventure Wagon. See more in their installation videos.What material do you have between the van wall and the L-Track?
Can you buy them separate from the bed kit?The orange material is steel braces provided by Adventure Wagon. See more in their installation videos.
DIY Installation
Adventure Wagon specializes in modular and configurable interior systems for vans. Because our interior systems are configurable, you'll be able to quickly swap them to meet your daily needs. Multiple configurations means greater usability. Find your adventure today with Adventure Wagon!adventurewagon.com
Not sure.Can you buy them separate from the bed kit?
The 3/16” took me hours. I was close to welding TH-1 to the van. However, the 25/64 weren’t to bad at all for me. I called AW and asked what bits they used (drill America) and ordered six of those after trying everything the hardware stores had. I then went with a really slow speed and used cutting oil. I think the best thing was using a foam yoga block between the drill and my shoulder. That allowed me to pull on the van structure with my left hand while phishing the drill with my right hand and shoulder while standing on a ladder for leverage. After giving it **** for quite some time it finally made it through.How the heck did you guys get through the top 2 holes on TH1 and TH3 wall braces for the Moab bed? I have went through 3 cobalt Bosch bits so far! Tried fast, slow, and slow with some dirtbike oil on it. Also tried a 3/16 cobalt bit and can’t get that through either. Of course the 25/64 bit size is weird and I can’t find it local on cobalt, so I keep having to order them.
This is obviously the boron hardened steel or whatever. I’m getting frustrated with it
What do u mean by recess area for the screws? The Moab braces seem like it’s all pop rivets and riv nuts. What are the self taping screws for that came with the Moab bed kit?Just watch the video - he does it in like five seconds, nothing to it!! 🤣
What's frustrating is that it's so early in the process and they don't give you a heads up, so you think you're doing something wrong and/or it'll take years to finish.
I bought a 3/8 hard metal bit from Home Depot. Get three while you're at it. Use that for most your drilling and save the elusive 25/64 bit to finish each hole, because, while they said they provided good quality bits and you shouldn't need more, that's total b.s.
I then used the smallest bit to drill the first part of the holes, then a Harbor Freight step bit to enlarge. I alternated to the 3/8 as I got closer. Took hours.
Also, there's a hole you have to drill at the bottom of those pieces that they don't ever tell you about. They go on and on describing it for TH2, then they don't mention it for TH3. Just make sure all the holes have a recess area for the screws.
Oh ok yeah I did use a step bit behind all of those. I don’t think my kit has the horizontal pieces since it’s just the bed kit. Although it still came with the self tappers. Idk I’ve never used L track so hopefully the rest is self explanatory.Screws to hold the L track to the THs go into pimnut holes in a lot of places, but the screws are longer than the holes are deep so they need a void behind it. Most the voids are already there but a handful you have to drill yourself.
I followed the AdWag directions exactly... and had to go and buy shorter screws because once it's all mounted, it's too late to drill the holes they failed to mention. An email to them confirmed they forgot to cover it fully in their videos. Oddly, he says how they forgot to film it for TH2, but makes no mention about TH1
He covers it for TH2 at about the 16:16 mark... but it's applicable to 1-4.
The self tapping screws are to hold the horizontal pieces steady while you're drilling them in. You remove them at the end - I just used clamps instead.
This post was a life saver. Worked perfect and my local harbor freight had both in stock.Progress today on the build. A-frame kit going up. Did struggle with upper C-pillar Boron steel. Not much guidance on how to deal with it from Ad-wagon. Consulted my machinist step-father and he gave me a couple of tips that really work for this area of the van
1 / Use center drill bits to start the hole
2 / Progressively use increasing sizes of cobalt drill bits to work up to 25/64 final hole size.
