1 - 6 of 6 Posts
I ordered our 2021 250 with the Adventure package and I thought it was going to come with the Upfitter switches but it didn't. I got the extra wiring harness, just no switches. Does anyone know if I was supposed to get the switches? The marketing package for the Adventure package showed a picture of them so I assumed I would.
Bruce
Bruce
It doesn’t come with the upfitter option, but allows you to add it as an additional upgradable feature for an additional charge. Basically you would just order that option. 67C
ADVENTURE PREP PACKAGE (47N)
Availability:
● Cargo Van and Crew Van
● 3.5L EcoBoost V6 (99G) Includes:
● 16” Black Aluminum Alloy Wheel (Standard Front Axle
configurations) – SRW only (647)
● 16” Black Steel Wheel with Exposed Lug Nuts (Heavy-Duty Front
Axle configurations) – SRW only (642)
● 16” Heavy-Duty Silver Steel Wheel with Exposed Lug Nuts – DRW
only
● Blind Spot Information System (BLIS®) (65A)
● Front Fog Lamps (55D)
● Auxiliary Fuse Panel with High Spec Interface Connector (87E)
● HD/SiriusXM® capability, SYNC 3 with 8.0” colored multi-function
touch screen, AM/FM stereo, Bluetooth, audio input jack, and Dual
USB port (58Y)
● Power Outlet – 110V/400W (90D) – Not Available on Crew Van
● Power Point – 12V (87A)
● Front Overhead Shelf – Medium and High Roof only (66D)
● Reverse Sensing System (43R)
● Side Sensing System (94A)
● Fixed Rear Cargo Door Glass and Fixed Passenger-side Glass
(17B) – Not Available on Crew Van
● Illuminated Sun Visors (85C)
● Adaptive Cruise Control (60D)
● Ebony Cloth, 10-way power heated Driver and 10-way power
heated Passenger seats (21R)
● Wheel Well Liners – Black (Front only) (15C)
● Privacy Glass (92E)
● Dual AGM Batteries (63E)
● Keyless Entry Keypad (52C)
Upgradeable Features/Options (for additional charge):
● Dark Palazzo Gray Cloth, 4-way manual swivel Driver and 4-way
manual swivel Passenger seats. (21T) – Not Available on Crew
Van
manual swivel Passenger seats (218) – Not Available on Crew Van
● Ebony Leather, 10-way power heated Driver and 10-way power
heated Passenger seats (21S) – Not available on Crew Van
● 60/40 Hinged Passenger-side Door (59A) – Low Roof Only and Not
● Extended Range Fuel Tank (655) – Not Available on Regular
Length
● Heavy-Duty Trailer Package (53B)
● Remote Start (68B)
● Heavy-Duty Cargo Flooring (60B)
● HD/SiriusXM® capability, SYNC 3 and a 8.0” colored multi-function
touch screen with Navigation, AM/FM stereo, Bluetooth, audio input
jack, and Dual USB ports (584)
● Front and Rear Split-View Camera (61D)
● Upfitter Package (67C)
Not Available with:
● Ambulance Prep Package – Cargo Van (47B)
● RV Prep Package (47D)
● Parcel Delivery Package (47G)
● Exterior Upgrade Package – SRW (18D)
● Exterior Upgrade Package – DRW (18L)
● Rear View Display in Rearview Mirror (61B)
● MyKey® (62B)
● Rear Bumper Delete (43F)
● Interior Upgrade Package – Cargo Van (96C)
● Load Area Protection Package (96D)
NOTE: Recommended exterior paint colors for the Adventure
Prep Package – Avalanche Gray (DR) and Abyss Gray
Well it looks like I blew that. Can it be installed after the fact?
Do you have the large console or medium console?
If you have the large console, you could probably purchase the switches and any needed harnesses.
If you have the medium console, you can still purchase the parts to change it to the large console, just a little more involved.
Bruce
That is why you should have received the preview order for your Transit so you would see all of the options on it. Using the 2021 Ford Transit Order Guide might have helped you or having got on the CrewVanMan 2021 B-O-B Transit Service last year would have possible got you the Transit you wanted.
The extra wiring harness you got was probably as part of the Heavy Duty Trailer Tow package. Was that one of the options you ordered?
Yes I did get the heavy duty tow package and the trailer brake controller. I did get the preview but thought the modified vehicle wiring option included the switches.
1 - 6 of 6 Posts
