Adhesive back Velcro wont stick for very long on interior panels,
3366 Views 39 Replies 18 Participants Last post by  brío
I installed some adhesive backed Velcro strips in numerous places to help hold my window shades in place. The adhesive on the back of the Velcro all fell off after a couple months. (Yes, I originally used alcohol to clean the spots before sticking on the Velcro strips.)( I have never used Armorall or other surface conditions on any of my interior panels.)
Has anyone found an adhesive (perhaps put it on the sticky part of the Velcro) that will stick long term to our interior panels, that eventually can be removed without discoloring or messing up the panels?
Reactions: 1
21 - 40 of 40 Posts
Have you ever used any of these products on corrugated polypropylene (Coroplast)?
I have not. It was the side view mirror, which I believe is was polypropylene.
Reactions: 1
I went to Wal-fart and purchased 3 different brands of double sided tape. 3M double sided VHB tape, Gorilla 38lb double sided mounting tape, and T-Rex "Super Glue" tape, I have 12 pieces of Velcro that have peeled off of the panels.
Using the 3 different tapes, I adhered the new tapes to 4 each of the velcro strips. Then cleaned each spot with alcohol, let dry, and then stuck them on. I will see how long each of them stick this time. An experiment in progress.
Reactions: 2
Window-shades, I'd go magnets. Our home-made window covers - old rig and this one - we have taped magnets onto them with gaffer's tape (lots of colors).
But all our wall-panels and cabinet panels are held on with Dual-Lock. Some clear, some black - didn't see any functional difference. Prolly different than flexible covers, though. But if you need to attach more solid stuff... crazy how well they work. All the panels on the walls, cabinets, and galley are "velcro'd" with Dual-Lock.
Automotive design Automotive exterior Gas Plant Machine
You can also see a bit of black gaffer's tape holding that crappy reflectix stuff up on the window behind.
Motor vehicle Vehicle Window Mode of transport Automotive exterior
I had the same issue and solved it with a few simple tricks:
1) Never buy Velcro that comes with an adhesive
2) Use 3M VHB 4950 (good heat tolerance) to create the initial attachment to a clean smooth surface, one piece on the van, a second piece on the item you want to attach.
3) Use Cyanoacrylate Adhesive (CA) between the back side of each half of the non-stick Velcro and the front side each of the two the VHB pieces from step 2.
After many experiments in the hot windshield area attempting to use Velcro for the top part of my sun shield I can confirm that the above steps finally worked and have held strong for four months even in high southwest summer heat.
It's possible the CA will fail at some point, but the adhesive velcro I tried initially was junk and did the exact same thing you described. And VHB alone wasn't enough to create a strong grip to the non-adhesive velcro. It's backside is woven and too uneven, but a CA layer helps make a smooth flat blond.
Cheers.
  • Helpful
Reactions: 2
For high temperature "Velcro" ready to go off the roll, consider the Dual Lock SJ3550 that is designed for vehicle interior attachments. Rated for 200F, outdoor use, and attaching to plastics. Not sure if it will leave a residue though.
Reactions: 2
Nice find! Looks like good stuff, and it's 3M, so that's encouraging.
VHB doesn't appear to leave a residue, at least not when I've removed it from interior surfaces (might after years, or on external).
But having an off the roll solution that lives up to its marketing would be very convenient. Next time I need more I'll give it a look. I already have VHB and CA for all kinds of things in the van, and I think the non-stick Velcro I got was like $8, but the day may come when SJ3550 makes more sense.
Cheers.
Cheers.
I've been using it to attach wood wall panels. I've had no issues detaching from the van paint after roasting all day in the hot Georgia sun. But it has detached from the wood panels that I apparently could not clean well enough prior to adhering. I fixed that with a couple 1/4" staples through the Dual Lock and into the wall panel.
Reactions: 1
Majority of tapes sold as 3M VHB are Fake - amazon
Real 3M VHB is Super Sticky and pretty much Permeant bond -
and Expensive
Once you use Real 3M VHB tape its easy to feel fake tape -
fake tape not even close to as Sticky as VHB
Real VHB tape is so sticky its kind of dangerous to use -
even the slightest touch with fingers and your Instantly stuck to tape -
RS Huges is a Good place to buy 3M tapes -
they sometimes give out Sample Packs that have about 15 two inch long tape samples-
rolls of tape cost $60 up - get smallest length roll -
Foam Core tape
Easiest to use tape has - Foam Core - makes tape slightly thicker -
foam core adds a Tiny amount of wiggle that helps tape resist shear and cleavage loads -
Foam core is Super strong - zero worry about tearing foam
tape that does Not have Foam Core is made for machine application and is
Super hard to apply by hand -
Make Sure to get 2 sided tape with ReLease Paper BOTH sides of tape -
this cost more but makes handling and application 100% Easier -
Practice on some scrap -
if exact location is nessary make a jig to help in placement of parts -
Once tape touches surface there is No adjustment - its One shot -
use plastic gloves - get Smaller gloves that fit Tight -
any excess of glove on finger tips will get stuck to tape -
I did some tests using VHB Foam Core
bonded to a 4 in aluminum I beam to 5 Ft long square solid aluminum bar
using 1wide x 1.5 long tape to bond together
Both surfers prepped
Bar was used as Lever -
when bond failed tape was still intact and tape had pulled a layer
of aluminum oxide off I beam -
back side of tape had layer of oxide that was shinny like a mirror -
was a Wow moment for me
On the strength of the piece to piece bond, YES, the dual lock is much stronger than regular hook and loop velcro. Often so strong that trying to separate the pieces will result in pulling the glued piece off whatever it's glued to.
That hasn't been my experience though. I'm clear on prepping and always do a through job. Velcro on my E-series plastic dashboard would always fall off (the glue between the Velcro piece and the dash would fail). I tried many times.
Friend gave me a piece of the Dual Lock mentioned above, and it has stayed stuck on my dash for 8 years now. And that includes a couple of Arizona summers, and down to around 30ºF in "winter."
I have since bought my own roll and used it to hang things like small photo frames on a Melamine type cabinet face (IOW plasticy and "slippery) and same thing. Backing stays affixed. (The two pieces stay stuck to each other as well, but that wasn't really my problem with the Velcro.)
That's one nice thing about the birchwood plywood from my local homedepot. It has a pre-finished side that's polished totally smooth. At one point they briefly only had another type that even on the finished side it was still a bit rough, and I'd imagine any regular plywood would always still be a bit too rough for good tape adhesion. But I guess you'd have to face the pre-finished birchwood side inward for that to be useful, which most people wouldn't want to do. I usually paint my birchwood white on all sides, so it wouldn't matter either way. But so far I've only been willing to bolt birchwood to the van because I'm typically loading the wood with some other heavy item. I guess when I finally get around the purely cosmetic wall and roof portions, this could come in handy though. Right now the plan is soft white synthetic leather or similar, so it may never be necessary.
Have you had good results with velcro for presumably 1/8 or 1/8 veneer type wall/roof panel mounting? I hit aggressive 4x4 trails all the time and worry it might come off, but maybe not with wood that thin or by controlling section size.
Cheers.
and Expensive
Foam Core tape
I've always bought from the 3M store on Amazon, which is both shipped and sold by Amazon, no third party. Only if you subscribe and save does it say a third party fulfills it.
3M - 1114112 - 1113996 VHB 4950 Heavy Duty Mounting Tape - 1 in. x 15 ft. Permanent Bonding Tape Roll with Acrylic Foam Core. Tapes and Adhesives https://a.co/d/g2nwjkn
But even VHB will struggle to adhere to any non-smooth surface, like weaving or uninished wood, especially if it's a high energy/hot surface.
And it can usually be removed easily from indoor clean surfaces after applying heat from a heat gun.
But after a year outside in the sun/dirt/elements, I could see it becoming a mess to remove. Outside the van I always bolt things.
Cheers.
An important consideration with VHB is the surface being attached to. For attaching to plastics, 3M sells a LSE line of products. For standard VHB 3M sells Primer 94 for attaching to low surface energy materials like plastics. My power step came with a couple VHB backed lights to illuminate the step. The VHB quickly detached from the plastic van trim after a misplaced step kicked the light. Reapplication with a little Primer 94 and the bond is solid.
Cheers.
My experience has been with 1/4" Birch side wall panels. I wrap the front in 1/8" landau closed cell foam and marine vinyl. Layers are stuck together with 3M 90 and secured with 1/4" staples on the back over wrap. The dual lock attaches to the raw birch veneer on the back and required a couple staples to stay secure. A 4ftx2ft panels uses six 1" square pieces of 250 density dual lock. Terrain has been on road so far, and the panels are also lighty wedged between cabinets in most places. They stay put.
Reactions: 1
The problem with bonging to plastic is that almost all Plastics outgas. This gas attacks the adhesive. To attach Velcro to plastic you need very good quality heavy duty Velcro. Then you need something between the Velcro and the plastic such as VBH tape or T-rex waterproof tape or 3m #80 Spray.
Clean the plastic with Alcohol.
Know the maximum weight or pull you need. tapes and Velcro are rated in pounds per square inch. 5lb PSI Velcro is 1" x1" and can hold about half its weight permanently.
Most people use too little Velcro or too small contact area.
If you want it removable use the tape method. The tape needs to be 4 times the surface area of the Velcro in the direction of the pull force. Then attach the Velcro to the tape.
Use 3m #80 Spray method for permanent bonds. .Mask off the area. Spray the plastic and spray the Velcro. Let each dry for a day. Spray each a second time. wait 15 to 30 minutes and press hard. Let dry for another day. It will not come off. Not without harsh chemicals anyway.
Hope this helps
...or, try RTV. If you are just holding up window shades, it will likely be just fine.
It is a cheap experiment.
RTV is a sealant and not intended to be used as a glue.
14 days later... Guess which tape has already fallen off?
Of these 3 tapes: 3M double sided VHB tape, Gorilla 38lb double sided mounting tape, and T-Rex "Super Glue" tape,
Drum roll.......
The 3M VHB tape has had 3 of the 4 pieces I installed fall off. The Gorilla and T-Rex tape are still holding strong.
  • Wow
Reactions: 1
This is inaccurate.
RTV has excellent adhesion to many materials, and is very commonly used as an adhesive.
It was used as an adhesive for the space shuttle thermal tiles, for example.
Orbiter Thermal Protection System Lessons Learnedhttps://forum.nasaspaceflight.com › ...
It also holds together most of the aquaria in the world.
One of the difficulties of adhering to automotive interiors is that the plastic is usually textured, which is a negative for many adhesives, but a positive for RTV. The adhesion to such materials is only moderate--adequate for OP's application, but not so strong that it can't be removed when desired. I use it regularly for such purposes. As I say, worth trying.
For clarification "RTV" is the process that the sealant or adhesive uses to cure. There are many different types of sealant and adhesives that cure via (RTV) room temperature vulcanization. Some silicone rubber based RTVs are only sealants, others are formulated to be adhesives and/or sealing adhesives.
  • Helpful
Reactions: 1
Our solar panels are attached to the roof with 3M VHB 4950. No screws. 6 years and counting.
Reactions: 1
Yes. I should have been writing "RTV silicone". In my circle, this is typically shortened to "RTV", but it is absolutely true that strictly speaking, that is a process, not a product. And, yes, there are many formulations of RTV silicone. I am referring to what you can buy at Home Depot.
21 - 40 of 40 Posts
