If yours are short arm I'll gladly sell you mine for a fair price
https://www.fordtransitusaforum.com/m hey digger337, did you ever have any luck getting the heated mirrors? I am looking to purchase a 2020 250 Mid Roof Cargo for my work van and it does not have heat or turn signals. I am looking to add both. I do t have the van yet, so am looking at what I need to do these upgrades myself, since Ford wants ridiculous money to do this now.I'm on a mission to add heat to my mirrors of my Transit 350hd. It was ordered as a low roof cab and chassis than a cargo box was added. So far I've found heated glass can be added very cheaply to the regular mirrors, unfortunately the 2 needed wires are missing from the mirror head harness to the plug in the door. A seperate connector with the two wires seems simpler than replacing the harness. If you replace the whole head, you'll not have this problem. I have the OEM switch to put in the dash in place of a blank just to the right of the instrument panel. I've yet to see if the harness plug is in place behind the panel. There are a few fuses and relays in the aux junction box who's presence need to be confirmed. I'm working with a full OEM wiring diagram book and will list what I find as I go. It seems the heated mirrors work of the rear window defroster( if equipped) which shares the power from the optional AC inverter circuit. One other issue is the CAN bus system that monitors everything. I will let you all know if that needs a reprogramming, it might. My transit had some different wiring options because it was produced in May of 2015, so newer vehicles will most likely have more extra wiring factory installed .
Thanks asdrew. I believe we chatted on FB about the turn signals, which led me to join here. Thanks! I saw these in my search for the turn signal parts and made me want them as well. I don’t have my van yet, but was wondering if the 2020 harness may have the wires I need already in the door. I am not sure what activates them though. I saw a few posts say the rear defrost turns them on. I don’t know if this van will have the switch, since it does not have any glass in the back. Do you have a good link or source to look up for a wiring diagram? Thanks so much.I got a pair similar to this from Amazon and ran the positive wire to the dash, but haven't taken the time to connect them to a switch yet:
Following this with interest, I'd love to add heat to the heatless mirrors I have. I do not have rear defrost though, do you think it would be feasible to run power to the mirrors using a totally aftermarket switch, say one of Hein's made to fit in the upper dash area around the gauges, and simply turn on and off manually? What sort or current draw do these mirrors have?Not sure how it turns on in a van without rear defrost though.
It is very feasible to run to an aftermarket switch. I would think the wires are in the factory harness in the door. I don’t have a van to verify that, but can’t imagine it is cost efficient to have multiple wiring harnesses across so many vehicles. Worse case if I can’t find the wires in the doors, I will run to an upfitter switch that the van I am getting has installed. Check out Amazon for the mirrors. The ones I saw was like $27.99 for the RH and less for the LH (for some odd reason). If I get the van and get into it, I will post back what I find.Following this with interest, I'd love to add heat to the heatless mirrors I have. I do not have rear defrost though, do you think it would be feasible to run power to the mirrors using a totally aftermarket switch, say one of Hein's made to fit in the upper dash area around the gauges, and simply turn on and off manually? What sort or current draw do these mirrors have?
Same up north here in Mississippi. Plenty of other things to work on. Keep us posted if you do finish it up sometime.Here in Florida we only need mirror heat for morning condensation, so it's not a priority.
I am in MS myself near Jackson. I was interested in doing both at the same time, because while I am in there, why not do it now?! Lol. We do have more icy mornings than FL, where I am from originally.Same up north here in Mississippi. Plenty of other things to work on. Keep us posted if you do finish it up sometime.
I replaced the glass with heated glass replacement panels and too apart the arm covering to install the wires that were needed to connect to the factory harness. I didn't use the ford repinning in the mirror to door harness, I cut the wires and went around the plug with insulated bayonet connectors. Polarity is of no concern of the mirror heater, so keeping track of which is which is not needed. I made sure all needed fuses were in there respective slots and all relays were preasent.https://www.fordtransitusaforum.com/m hey digger337, did you ever have any luck getting the heated mirrors? I am looking to purchase a 2020 250 Mid Roof Cargo for my work van and it does not have heat or turn signals. I am looking to add both. I do t have the van yet, so am looking at what I need to do these upgrades myself, since Ford wants ridiculous money to do this now.
Is the OEM switch a rear defrost switch? Do you happen to know the part number you purchased. My van is supposed to be delivered next Wed, so I want to start ordering parts ASAP. Thanks for your insight.I replaced the glass with heated glass replacement panels and too apart the arm covering to install the wires that were needed to connect to the factory harness. I didn't use the ford repinning in the mirror to door harness, I cut the wires and went around the plug with insulated bayonet connectors. Polarity is of no concern of the mirror heater, so keeping track of which is which is not needed. I made sure all needed fuses were in there respective slots and all relays were preasent.
The next step is to tear apart the dash and add the oem heated mirror switch but that's as far as I got ,other priorities have me occupied.
I'm hoping I don't need to program and reflash the bcm but I'm set up to do it with Ford etis and a 3 yr access license. Will post when I finish.
Also how did you attach your wires to the mirror glass. I would imagine Ford has a plug that attaches to it, but looks like maybe flag terminals would work. I just am not sure if water intrusion from around the mirror would be an issue.Is the OEM switch a rear defrost switch? Do you happen to know the part number you purchased. My van is supposed to be delivered next Wed, so I want to start ordering parts ASAP. Thanks for your insight.
I don't recall the exact connectors I used, but something like this will work to push onto the pins. As long as you don't have just bare wires on there you should be fine.Also how did you attach your wires to the mirror glass. I would imagine Ford has a plug that attaches to it, but looks like maybe flag terminals would work. I just am not sure if water intrusion from around the mirror would be an issue.
Thanks asdrew! I will be getting my van in a few days and then I will be really investigating everything! Thanks!I don't recall the exact connectors I used, but something like this will work to push onto the pins. As long as you don't have just bare wires on there you should be fine.
