Has anyone successfully added a 3rd battery to the dual AGM stock setup? The van has dual alternators onboard as well.
I want to avoid buying another large battery. adding another 70Ahr battery would be plenty to support my planned setup. (LEDs, water pump, USB charging, and webasto heater)
is this possible? I imagine it should be, but I'm not well versed enough on the stock wiring setup. Can I just hook it up I'm series with appropriate gauged wire and be good to go?
I'm Ok with having house and crank battery be on the same setup. I'd rather have a jumper on hand than install a separate house battery system.
please resist the "you need a separate house battery" thread hijack
