Yup, got the new Defenders LTX/MS on, 245/75/16
First the difference in size alone, @70 MPH (gps) is actually 65 MPH speedo. Also @ 70 MPH my RPMS are spinning two hundred lower than stock size. I had to remove my front mud flaps they where rubbing
, which is now big deal cause I got their for the winter, so when I put my winter tires on 235/65/16. I oringinally ran 70 PSI all around for a few day, but the ride was a little rough, so I lowered them back to 60, bingo
Now about the tires, I measured the tread depth which was exactly 11 MM, the Handkrapps where 10. I actually gained about 1.5 MPG over stock. This was based on a 600 mile ride I took today doing 65 MPH 95% Interstate, which I did numerous time with the Handkrapps. Michelin also rated this tire with a 50,000 mile warrenty so time will tell. Also these tires are quiet, but sensitive to bumps and Expansion joints. Well that's about it, so stay tuned for my 10,000 mile report, where I will address the wear rate
