245/75 pressure
1 - 9 of 9 Posts
2020 Transit AWD 250 mid roof
Just curious what pressures others are running at on their 245/75 tires, especially for the snowy conditions ahead?
Stock pressure?
-5 psi?
-10 psi?
2018 Transit 250 SRW HR EXL 3.7L 4.10R Dual AGM
Stock unless I am off-road, then I'll drop down to 30 or 35 depending on conditions and what not.
EDIT: I am using 245/75R16 BFG K02's all around, various loads all the time from total vehicle weight of 6500 up to GVRW of 9500 (and even above before oops LOL)
Stock pressure?
-5 psi?
-10 psi?
I ran stock pressures for the last 2 years and rotated my Pireli Scorpions AT+,tires every 5K. I had great wear on all tires. +- 1/32". I really think that weight in the rear is the only wildcard for reducing pressure, other than off roading.My van weighs in at 8200#s. Winter traction IMHO,seems to be much more dependent on the tire makeup. I.E. winter tire with softer compound and tread design.
I am really really surprised that this post is not getting more traction, I would have assumed this post would blow up just like all the other tire pressure posts out there.
Maybe if it also asks what brand of oil to use...?
2019 Transit cargo, HR, 3.5 Eco, Quigley 4X4, “Vandemic”
I have BFG KO2 tires 245/70 R17and based on CAT weight (8960 lbs; Front axle 4020; rear axle 4940) and rating of the tires from BFG charts, I run 45 lbs in the front tires (2010 lbs each) and 65 lbs in the rears (2470 lbs). I run 35/45 off road.
I have 245/75R16 AT3W's on my Quigley wagon and I like 45psi front, 60psi rear. I weighed it at first and used that to set the pressures ~45psi for both but the back felt unsure so I raised it a bit.
1 - 9 of 9 Posts
