Throwing this one in the mix.
2021 Ford Transit 250 MR 148” WB (non-extended), AWD, Avalanche grey, Ecoboost, swivel seats, dual batteries, power sliding side door, see window sticker pic for all options.
Pinnacle Campers build, set up with indoor/outdoor kitchen and dinette seating for two at the swivel seats or at the driver’s side bench seat utilizing a swiveling table mount and wood laminated table top. Loft bed with 36” clearance for bikes. Tons of storage in the cubbies and built in crate/bin cabinet, inside the bench seat, or kitchen cabinets.
Interior standing height is about 5'9-10"ish.
Lithium battery package with 30amp vehicle charging and 200 watts of solar powers a 12volt Dometic CFX3 45L fridge, remote controlled vent fan, front, rear zoned and dimmable lighting, and 110v outlet for laptops/charging.
Water storage includes an under floor mounted fresh water tank which supplies the faucet with pullout sprayer, sink, and rear outdoor shower port with hand held shower head.
Exterior goodies include a 2" lift kit, larger tires, rack, front skid plate, ladder/spare tire rack, opening windows in the rear doors, and the driver an passenger side forward window positions.
This van is currently ready to GO!
Van has <750 miles.
Full spec sheet below
$123,500
This van was built and being sold by Pinnacle Campers LLC
2021 Ford Transit MR AWD Kestrel build
Upfit:
Driver and passenger side CRL awning windows
Rear door windows with slider and screens, VWD
Rubber coin floor, black
3M Thinsulate insulation, roof, walls, rear and slider doors
Custom interior headliner wall panels and coverings. Automotive tweed (Tuxedo), grey wood accents, black vinyl
Custom Interior Cabinets- "What a maroon" epoxy, grey wood accents
Pinnacle Campers kitchen cabinet with exterior drop down table, two large cabinets with interior/exterior access, drop doors, slam latches, laminated countertop, setup for Dometic CFX3 45L fridge. Pinnacle Campers bed kit set up for "east/west" sleeping, Full 52x75. Wheel well storage cubbies, powerwall/integrated batteries, removable platform slat panels. Crate cabinet with bedside countertop.
Bench Box 50", foam/vinyl upholstered backrest and cushion split at 50/50, storage under, porta-potty locator inside
Electrical: Capacities: 200ah storage, 200w solar, 30 amp engine charging, 375 watt AC
2x 100ah AIMS power Lithium batteries with internal BMS, bluetooth voltage monitor
VictronVA375 inverter, 1 single outlet front, 1 duplex outlet D/S cubby
Victron Orion DCDC Charger 12/12 30a
Victron Smartsolar MPPT 75/15
Solar panel, 200w/24volt
Blue Sea fuse block with ground, 6 position, 2X DS/PS
Exterior LED porch light on kitchen, 6 ceiling lights with dimmer, 2 zones, switched at two locations
Bed pod cubby lighting, switched at two locations
USB @ 5 locations, DC cig plug 1 location
2 multimode reading lights
Automated heating circuit for lithium batteries
Control panel and concealed Powerwall
Water system: 16g fresh, 10g grey
Stainless sink
Faucet, single handle, pull out spray, black
Pump Shurflo 3gpm
Fresh tank 16 gallon under mount (PS) with aluminum skid plate, slider door fill, vented @ fill
Grey tank 10 gallon under mount (DS) with aluminum skid plate, manual dump valve, vent/over flow
Woder 10K water filter (assumes clean water in tank)
Rear shower quick connect port and handheld sprayer with shut off
Appliances/Accessories:
Lagun table leg with laminated table
Nightfall Overland shades for windshield and cab doors, driver and passenger side forward window. Custom zippered shades for rear door windows.
Mattress: Memory foam tri fold 4”
Dometic CFX3 45L 12v refrigerator on DFG offroad pull out side.
Espar Gas fired heater, with easy start controller
Maxxair 6200K roof fan, white lid
Kovea propane cooktop. Stows beside fridge.
Camco portable potty 2.6g
AVC RIG roof rack
Limitless van ladder/spare tire rack
Van Compass Topo 2.0 Lift, blue springs, rear shock tower extension brackets, Installed with Alignment
Pirelli Scorpion ATPlus 245/75/16 x5, with 5x powder coated wheels and black textured caps
Bug screen kit, Pinnacle Campers, slider
Bug screen kit, Pinnacle Campers rear garage
