2020 Ford Transit 250 Cargo Van Medium Roof 148 inches (Not Extended) Sync/Nv Tow Package
7,300 miles. Certified Pre-Owned.
$77,000.
Custom Conversion completed May 2021, by Alex Gaebe, Carolina Van Builders
Selling due to life changes. Videos.
Located near Asheville, NC.
BUILD
$77,000.
BUILD
Features: | |
(1) Fantastic Fan 1250 | |
(1) Maxxair 6401 | |
Webasto heater | |
Sliding door window | |
20 gallon fresh water wheel well tank | |
5 gallon grey tank under sink | |
Solar: | |
Hookup for portable solar panel | |
30 amp Victron solar charge controller | |
Electrical: | |
(2) 100Ah LiFePo4 Victron Superpack batteries | |
30 amp shore plug | |
2000 watt Victron inverter/ charger | |
30 amp Sterling Alternator B2B charger | |
Electrical panel including all chargers, breakers, fuses, and disconnects mounted under bed, driver’s side. | |
LED recessed puck lights in ceiling, under overhead cabinets | |
12VDC power at fridge, water pump, lights, heater and fan locations | |
120VAC USB outlets: by bed (accessible when bed is up and down), over both counters, rear side of driver’s side cabinet | |
Insulation, Subfloor, Framing: | |
Wool insulation in the walls, ceiling, and doors. | |
¾” foam board insulation on floor. | |
¾” plywood subfloor overtop ¾” batons secured to vehicles floor with adhesive | |
1”x3” furring strips framed on walls/ ceiling | |
Paneling, Finished floors: | |
Flooring: LVL or engineered hardwood. Trail oak | |
1”x 6” clear pine T&G ceiling | |
1”x 6” clear pine T&G walls | |
OTHER EQUIPMENT | |
Dometic Fridge / Freezer | |
Dometic CFX 95DZ Black/Gray 12V Electric Powered Portable Cooler (Frdg/freezer) | |
CampChef Ranger III: 3-burner Propane Stove | |
STEELCRAFT STX600 RUNNING BOARDS | |
Insulated Magnetic Window Covers - all Windows | |
Only Rear door not super insulated | |
Mattress | Wayfair Sleep 5" Firm Gel Memory Foam Mattress |
By Wayfair Sleep™ Mattress Size: Full | |
Mattress cover | Betances All in One Bed Bug Blocker Hypoallergenic and Waterproof Mattress Cover |
By Alwyn Home. Size: Full. Never Used. | |
Sheets | Pottery Barn PB Classic 400-Thread-Count Organic Percale Sheet Set, Full, Classic Ivory |
Washed, Never Used | |
Tarp Poles and Suction Cups | |
Telescoping Ladder | |
ACOPower 120W Portable Solar Panel Foldable Suitcase With Built In Integrated output Box | |
--Plus ACOPOWER 20FT/14AWG Solar Extension Cable with MC-4 Female and Male connectors | |
Drinking Water Hose | |
Shore Power Extension Cord |
