Hi all, I've got a 2020 Transit with the dual AGM battery and dual alternator option. I plan to install a lifepo4 battery bank of somewhere around 400-600ah (undecided on 12v or 24v still) and I'm trying to figure out how to set up my electrical system to maximize the charge going into my house battery bank. I've seen this topic discussed a lot here on the forums and was originally gonna piggyback onto some older threads, but then thought it might make more sense to create a new thread so as to not hijack others threads.
For reference, I've read the following threads on this subject thru a couple of times over
800AH LiFePo4 - 2x250Amp Alternators - How to maximize?
Charging Large (800 amp hour) House Battery Bank from Alternator??
2020 Transit -- Alternator Charging the House Batteries
Fast charging advice needed: dual alternators, 2020 Transit all electric LiFePO4 campervan
Here are my basic electrical needs
Energy Needs
I've calculated that I need roughly around 5000 watt-hours of energy per day, with a peak of around 2500-3000 watts max surge load if I avoid running multiple high watt devices at the same time (cooking mostly)
Charging
I want all of the following...
(Solar) Rooftop mounted solar panels - depending on the system config I could possibly at most get 600-900 watts of solar
(Shore) Connect to standard 15amp household service (maybe 30 amp RV style, but not sure)
(Vehicle/Alternator) Would like to be able to charge my house batteries via alternator when driving at the maximum amperage for the alternators and electrical system (175-200 amps peak?) that the Ford system allows for with safety headroom.
Based on reading all of the threads listed above I see that this has been talked about a lot on this forum and that many members have 2020s with large battery banks and they're trying to accomplish the same thing. It seems to me that there are two possible paths to take...
1) Use CCP2 and connect a DC-DC charger (or multiple DC-DC chargers in parallel) pulling up to about 160 amps from the vehicle battery system and sending that over to the house battery system with the correct lifepo4 charge profile.
2) Use the DC-AC-DC method with multiple inverters, where one inverter is connected to CCP2 and acts as the current limiting device, which then sends power to the second inverter or shore charger that can then charge the battery. (I might not be understanding this correctly so please correct me if I'm wrong)
Are there other options that I'm missing here? I've been stuck for a couple of weeks now trying to figure out what path to take here.
Another compounding factor with my system design is trying to figure out which direction to go with the pack voltage. Was originally going with 12V, but so many have suggested going with 24v based on having a roughly 3000 watt inverter needed for loads that I would be better served, safer, and cheaper to go with 24v. That all sounds good, but it causes headaches in terms of charging via the alternators since I'm having to deal with going from 12v (vehicle) to 24v (house) which means I'm losing amps making the jump up to 24V in the DC-DC scenario (unless I'm missing something)
Would love to hear from those that have experience here for any insight they can offer? @orton @Vanpackr @keitho @DanD @harryn @huj @epiphVANy
Thank you!
Energy Needs
Charging
Thank you!
