361 - 372 of 372 Posts
The fit is ok but I'm not totally happy with the final look. Not sure what I'm going to do?
I have seen where someone filled in the hole where the mounting pin with spray foam. I suppose the other divots too?
I filled the hole with spray foam and cut the end off above the slider door for longer storage above the slider door. Only problem is the foam continued to expand long after I had sanded it flush and painted it. Need to go back and get it flush again and then repaint it. Biggest eyesore in the van.
2020 AWD Transit 250 MR
Discussion Starter · #363 ·
Thanks guys! I think I'll see what the wife says? She might like it? If she's cool with it I am too. But if I can get my hands on a new block I think I'll give it another try cutting it out.
Discussion Starter · #364 ·
Another fail, thought this might look good but I don't like it. However, if I can get a new block I can use the old one as a template and get a good fit.
Photograph Tire Wheel Black Automotive tire
Comfort Rectangle Tints and shades Wood Armrest
Automotive design Motor vehicle Automotive exterior Automotive tire Vehicle door
I had to buy more upholstery and it also looks like a different shade of gray!
Dave - if you would mess up more often, then you wouldn't notice it. :)
Discussion Starter · #367 ·
When I was building the face frame for the cabinet I made the bottom rail too short. I built the first face frame one piece at a time, I cut the individual pieces and then brad nailed them to the cabinet. After watching a few YouTube videos on making cabinets l learnt that the best way to do it is to build the whole frame first then mount it to the cabinet.
Property Shade Interior design Building Wood
You can see the mattress is higher than the bottom rail so I couldn't open the cabinet doors when the bed was down.
Cabinetry Shelf Wood Shelving Interior design
The old face frame came off easy.
Line Asphalt Engineering Wood Technology
Built the new face frame using pocket holes. It's definitely a better way to do it and really solid too!
Rectangle Wood Floor Flooring Gas
With the taller bottom face frame the bottom drawer would no longer open, so I had to move the drawer slides up higher. Both drawers still fit but they are really close so I had to add a handle. I only had one left so I'll have to order another one.
Furniture Wood Rectangle Drawer Wood stain
Shipping box Wood Rectangle Shelving Flooring
I also had to add some edge banding.
Blue Interior design Floor Flooring Wood
The new face frame fits great, hopefully I can paint and install it tomorrow.
Building Wood House Shade Wall
It'll be tight but I can install the cabinet doors so they don't come in contact with the mattress.
Discussion Starter · #370 ·
Worked on making new cabinet doors.
Automotive lighting Automotive tire Wood Road surface Asphalt
Used the router table i made to make the grooves for the center panel.
Brown Rectangle Beige Wood Textile
Tedt fitted all the cabinet doors.
Wood Asphalt Floor Flooring Road surface
Glued up the doors
Hood Yellow Wood Gas Engineering
Wood Hood Table Automotive design Floor
Rectangle Wood Table Beige Flooring
Then I did a lot of sanding. I'm going to find someone to spray paint them.
Discussion Starter · #371 ·
Did some more sanding and installed the hinges.
Blue Saw Asphalt Liquid Gas
Used some glue and sawdust from sanding to fill some cracks.
Wood Rectangle Floor Grey Flooring
After a little sanding they look great and I'll be painting them.
Product Azure Gas Electric blue Font
The Kreg jig works great.
Wood Wood stain Floor Material property Hardwood
Wood Grey Beige Floor Rectangle
Automotive tire Handheld power drill Pneumatic tool Tool Hammer drill
You can also drill the holes for the hinge.
Discussion Starter · #372 ·
Attached the doors to the face frame.
Wood Interior design Boat Floor Cabin
Door Fixture Wood Flooring Floor
Cut a piece of wood to help install all the doors at the same height.
Wood Fixture Vehicle Floor Door
It's a tight fit but they do open.
Wood Interior design House Flooring Floor
Building Furniture Shade House Door
Got them all installed, it was a little dusty after sanding!
Door Flooring Floor Wood Real estate
Time to remove the face frame and doors. Hopefully, I can find someone to spray paint them!
