341 - 360 of 372 Posts
2020 AWD Transit 250 MR
Discussion Starter · #341 ·
Still working on the ceiling transition to the cab overhead.
Rectangle Textile Beige Wood Sleeve
My fancy scribe tool, it works great! I started scribing with cardboard.
Hood Automotive lighting Automotive mirror Motor vehicle Vehicle
Then I traced it on to a piece of 1/4 inch which i can sand it down easily to get a better fit.
Wood Shade Gas Tints and shades Composite material
Hood Wood Shade Rectangle Automotive exterior
Next, I trace it onto some 3/4 plywood and do a little more sanding to get a better fit.
Wood Floor Shade Flooring Ceiling
Road surface Wood Asphalt Yellow Track
I added a bottom piece that'll make a nice transition. Tomorrow, I'll covering it with upholstery and install it. I want to think about how I'm going to install overnight.
Wood Automotive exterior Line Boats and boating--Equipment and supplies Wood stain
I un clipped the 3 clips holding the overhead panel and stuffed it with Havelock Wool to make it straight instead of a slight curve, this will make the transition piece look really nice, I hope!
Discussion Starter · #343 ·
Thanks, enjoying your build too! It's going to be a cool night!
Discussion Starter · #345 ·
Adding upholstery to the transition piece.
Wheel Automotive tire Tire Road surface Asphalt
This glue works great, I sprayed it on both halfs and rolled the wood over onto the upholstery, worked great and no wrinkles.
Hood Automotive lighting Automotive design Motor vehicle Vehicle
I also added some staples.
Hood Automotive tire Motor vehicle Vehicle Automotive exterior
One screw in the middle, which my wife is going to cover up and the screw on the side will be covered by the styrofoam block.
Motor vehicle Automotive design Vehicle Automotive exterior Mode of transport
It's really solid and fits great.
Vehicle Automotive mirror Automotive exterior Mode of transport Automotive tire
The transition to the cab fit well too and the color is a really close match.
What is the color of the fabric and your source? I believe marine/auto upholsterers sometime use a product called landau foam underneath (high density, closed cell). Not sure how it is to work with. If I was to guess, it might make it easier (faster) to get good aesthetic results?
Discussion Starter · #348 ·
Here's the link to it on Amazon, this one has a foam backing on it. Amazon.com: Light Gray Upholstery Auto Pro Headliner Fabric 3/16" Foam Backing 120" Long X 60" Wide : Automotive
Discussion Starter · #349 ·
Yesterday I started working on the trim piece above the side door.
Plant Motor vehicle Automotive exterior Asphalt Bumper
Added some support and mounting pieces.
Shade Plant Wood Tints and shades Leisure
Cloud Light Sky Shade Rectangle
It took a few tries to get the angle correct.
Automotive tire Hood Gesture Wheel Automotive design
Scribing the bottom piece was definitely a challenge! Took way too many tries! I'm also going to add upholstery to the metal so I hope the seams tighten up nicely?
Automotive tire Hood Motor vehicle Tread Automotive exterior
Glued and brad nailed it together.
Automotive tire Infrastructure Road surface Asphalt Motor vehicle
Had to cut the the top at an angle so I could get a tight fit on the ceiling.
Automotive tire Yellow Asphalt Road surface Rolling
used a flush trim router bit and a sander to get a nice flush surface. I'll close that gap up when I attach the upholstery, when it's installed the gap will be tight and straight. I don't think you'll see it.
Plant Window Building Tree Automotive exterior
Discussion Starter · #350 ·
Still working on this piece!
Hood Rectangle Road surface Automotive tire Wood
When I install it, it'll bend up, so I cut a few grooves to help it bend slightly.
Road surface Wood Rectangle Asphalt Public space
Glued and nailed it together.
Wood Road surface Rectangle Table Flooring
Automotive tire Road surface Asphalt Wood Line
I clamped it to the work bench and then move a piece of wood under the other end till it was a tight fit. Worked great.
Rectangle Wood Road surface Flooring Floor
It fits great, now time for some sanding.
Tire Automotive tire Wheel Road surface Wood
Wood Rectangle Floor Wood stain Plank
After sanding it fits great.
Aircraft Airplane Wood Aviation Flap
Decided to use a router to make a slight curve, should look nice when I add the upholstery.
Discussion Starter · #351 ·
Started working on some upholstery to finish off the front area.
Tire Hand Hood Automotive lighting Automotive tire
Green Azure Textile Thigh Headgear
Came out nice around the corner
Hood Automotive tire Sky Vehicle Motor vehicle
Removed the trim, the center trim piece comes off first and i just loosened the top one and stuffed the upholstery under it.
Automotive tire Vehicle Automotive lighting Automotive design Car
I also removed the handle and then re-installed it.
Automotive tire Gas Automotive exterior Auto part Automotive wheel system
I also removed the Lagun table mount, I only upholstered down to the first screw.
I put the door rubber back on and it still fit really well.
Did you remove the bottom plastic trim piece on the B-pillar to run your floor underneath it? Hard to tell from your last photo. I'd like to go that route but cant figure out the clips and I don't want to bust anything. Oh yea, nice upholstery.
Discussion Starter · #353 ·
Hello, the floor wouldn't fit under that trim piece so I cut the floor to go around it.
Yup and it seems that is what most folks have done. My thought was to cut the trim so the floor went under it, I could seal it to the B pillar. Nice win by your Sox last night.
Discussion Starter · #356 ·
Finishing up the trim piece and adding some upholstery
Rectangle Wood Road surface Asphalt Beige
Plant Wheel Vehicle Car Tire
Not a bad test fit
Plant Building Shade Interior design Floor
Vehicle Motor vehicle Mode of transport Automotive design Plant
Tire Plant Automotive tire Automotive lighting Tread
Hood Automotive tire Automotive design Automotive lighting Vehicle door
This piece took forever to finish, now it's time to install it. Next will be trying to get the styrofoam block to fit and try to make it look good!!
Discussion Starter · #360 ·
Upholstered the styrofoam block, it's definitely a challenge to do! Wish it came out better but it'll have to do for now. Might try to buy a new one, if I can find one?
Plant Automotive tire Automotive design Vehicle Automotive side-view mirror
It fits nicely with the cab liner.
Automotive design Automotive tire Rectangle Motor vehicle Grey
I'm not happy with the open area at the top, I might make a small block to fit in there?
Building Motor vehicle Automotive exterior Vehicle Mode of transport
Hood Building Automotive design Motor vehicle Sky
The fit is ok but I'm not totally happy with the final look. Not sure what I'm going to do?
