2017 Ford Transit 350 * SRW * Tall Extended * 3.31 Limited Slip * 3.5 Ecoboost
Trailer Hitch * power mirrors w/ turn signals * Cruise Control * 9500# GVWR
10 way Drivers Power Seat *22,000 miles $65,000 or offer
Camper Conversion includes :
(2) Renogy 105 AH Smart LiFePO4 Batteries ( new on 10/27/2021)
(2) 160 watt Renogy solar panels
KISAE DMT1250 charge controller
Victron Battery Monitor
Blue Sea 12V and 120 Volt panels
Smart Plug 30 AMP shore Power outlet and breaker
50 ft Smart Plug cord
Renogy Pure Sine wave 1000 Watt Inverter Charger
Manchester 5.5 gallon under body Propane Tank
Propex HS 2800 Propane Heater
Maxxair Fan + Maxxfan Dome Fan w/ LED light in Bathroom
Thetford C402 Cassette Toilet with hatch to drivers side exterior
(4) Motion windows installed by Factory in Vancouver, WA
Isotemp Spa 15 water heater plumbed to engine coolant
Change over to Yellow coolant
20 Gallon Freshwater tank
Shureflow 4008-101 water pump with accumulator
25 Gallon Gray Water waste tank
3 burner Propane cook top
Stainless microwave with power adjustment (will run on inverter)
Shower stall with Delta faucet and hand shower
Stainless kitchen sink with drain board
Dinette Table has 2 stage hydraulic base
Scopema swivel base on passenger seat
Fumoto Oil Drain Plug
Thinsulate Insulation in walls and ceiling, Minicell under baltic birch floor
Upholstery is Sunbrella by "Cushions Express" there are 4 back/filler cushions, easy to order more.
Slight body damage to top of rear door (tree branch) doesn't effect the function of the door.
Located in Friday Harbor, WA walking distance from the Ferry.
