1 - 3 of 3 Posts
I have had my 2016 long wheel base high roof T350 for over 1 year 38,000 miles on it now. My only complaints are The Sirus/XM radio cuts out all the time It says Acquiring signal. been back to the dealer more than 6 times they say it is because of cell towers and they have no fix. (doesn't happen to any of the other 4 Sirus/XM radios I have)
The rear brakes have been changed twice the 1st time around 18,000 and now at 38,000 miles.
Last my rear cargo window on the drivers side broke and fell out
EMF problem? I got my Faraday screen material at West Marine. LORAN stuff. "Air-burst" lost a year of production do to EMF. They forgot to "twist the wires". The actual problem was wire bundles that were too close together. Bundles were moved.
I'm confused. I thought Sirus/XM was Satellite radio. Under passes, dense trees, anything blocking the signal from overhead will cause it to search. EMI could be an issue but I doubt it. The cabling for the antenna is shielded and bonded at the connector.
Sent from my SM-G955U using Tapatalk
1 - 3 of 3 Posts
