1 - 4 of 4 Posts
2016 Transit 350 LWD High Roof Extended
Yes, another stereo wiring thread.
I am moving from a single to double din stereo in my 2016 Transit. There are several parts coming out with connections that I need help identifying. Specifically, the OEM stereo took two connectors and I can only find the pinout for one of them. Alternately, the control panel has connections as well and I wanted to make sure none of those are important.
The parts going in
Dash Mod: Metra 99-5832G Single/Double Din Dash Combo Kit for Select Ford Transit 2015-Up
Stereo: https://www.amazon.com/dp/B08HPZP1NV
USB Port: Amazon.com: 2 Ports Dual USB 3.0 Male to USB 3.0 Female AUX Flush Mount Car Mount Extension Cable for Car Truck Boat Motorcycle Dashboard Panel -(3 Feet) : Electronics
Parts Coming out:
Stereo - CK4T-19C107-DB
Control Panel - DT1T-18K811-CD
My stock harness has the following pins in the 24 pin connector:
1) Battery
3) Starter Motor Control Sense
9) Speaker -
10) Speaker -
11) Speaker -
12) Speaker -
13) GND
14) Illumination +
15) Illumination -
21) Speaker +
22) Speaker +
23) Speaker +
24) Speaker +
158761
Missing leads:
I understand my model might not have these, but I wanted to make sure they are not available from one of the other connectors. Can I pick these leads off the 2nd stereo connector or the control panel connector?
  • Accessory / Ignition +
  • Parking Brake -
  • Steering Wheel Key (SWC) 1 +
  • Steering Wheel Key (SWC) 2 +
  • Steering Wheel Controls (3.5mm jack)
The image below shows the two ports. Not my stereo...
158760
Discussion Starter · #2 · (Edited)
I think throwing money at the problem is the best solution for this problem...
I wound up getting the following bits from Axxess:
  • AXVI-5524 - Replace Factory Radio Harness
  • AXSWCH-FD1 - Retain Screen Harness
  • ASWC1 - Steering Wheel Control Interface
I'm guessing you're up and running. Any pictures or feedback would be greatly appreciated.
Thx
1 - 4 of 4 Posts
