1 - 5 of 5 Posts
If anyone could help translate it, I'd appreciate that very much. I have dug around the interwebz and here, and I'm still confused. It seems Bismarck has some bonus features but a lot is called 'no charge' (nc) so is it correct to assume the "free" stuff is part of a package as listed? This is my first Monroney sticker ever. Thanks for your help!
Optional Equipment
Preferred equipment package 101A
3.5L GTDI V6 engine
(nc) 3.31 ratio rear axle x31
(nc) front license plate bracket
(nc) floor covering vinyl front
(nc) 9500# gvwr package
engine block heater
(nc) 50 state emissions
reverse park aid
mirrors, long power/heat
front rear a/c
cruise control
rear view camera
(nc) heavy duty alternator
dual heavy duty batteries
dual illum sunvisors
cargo area led load comp pkg
keys 2 additional
power inverter
Most of those items are self-explanatory, which particular ones do want to know more about?
I believe Preferred equipment package 101A just indicates that it has the standard cargo van equipment. The items listed as (nc) are part of other options or required equipment.
Ah, ok - that's the main confusion. I was trying to figure out what the 101A package meant - if there was something separate or if that was the (nc) list of items. There is a specific amount for each of the other items, but then the alternator (nc) is thrown in below other items that have pricing. The cargo area led load comp pkg was something else I couldn't translate. I have the floor mat but the interior panels I've seen on others' vans aren't there.
When I discovered the AC plug under the parking brake, I thought I won the lottery! I figured I ought to get the sticker to find out if there were more surprises. The engine block heater was definitely news to me. I also need to figure out how to turn on the mirror heaters since I apparently have those as well. Then again, neither of those will get a whole lot of regular use here.
Thank you for your help!
101A is the code for a cargo van.
Cargo area LED lighting is part of the cargo package .
The (nc) HD alternator comes with the rear AC.
The (nc) front floor mat is part of the 101A package
The mirror heat I believe comes on with the defroster.
Discussion Starter · #5 ·
Once again, appreciation for your time and information! I have not had the van long enough (or the attention to focus enough) to get to know Bismarck very well. This really helps!
1 - 5 of 5 Posts
