2010 Transit Connect won't up-shift into highest gears
1 reading
32 views 2 replies 2 participants last post by  donparadowski
#1 ·
After a six-month storage my Transit won't upshift to the higher gears. It worked perfectly when I stored it. Now at 70 mph the motor is running at 4100 rpm's. The fluid level is correct. Anyone that can advise me would be greatly appreciated.
#2 ·
Count the upshifts. Is It using all 3 lower gears, and just not using O/D? Is the Overdrive light on?
If 1-3 are shifting normally, and your O/D light isn’t on… make sure the parking brake isn’t stuck and dragging. The extra load will keep it out of OD.
Also check that there isn’t a rodent next in the air filter housing. If the intake is blocked, it won’t’ make as much power, but the shift paints are programmed based on throttle position, so it then it won’t upshift based on the extra throttle command.
