1 - 9 of 9 Posts
2017 350 XL HD passenger
Anyone have any experience with this unit in particular from superbrightleds.com It uses a controller and then RF wireless wall switch or a micro button/switch. The switches run on a coin cell battery (3v). I like you can put multiple switches around the cabin without having to run wires all over the place. Just curious how well they work in the van and also in varying cold/hot weather conditions.
Wireless Single Color LED Dimmer Switch for EZ Dimmer Controller | Super Bright LEDs
Wireless LED 1 Channel EZ Dimmer Controller | Super Bright LEDs
Hopefully someone will have specific experience with that unit.
We have used a couple different Chinese-brand-of-the-day RF controllers from Amazon (LEDENET was one - now something else) and have been able to program them with each other with some hassle. IOW, they have all been similar-ish enough to talk to each other so far. And have worked for years in the Sprinter and a year-and-a-half on the Transit.
I want something like this for led strips down near the floor and under the overhead cabinets.
I am not sure about that specific unit, but that supplier ( superbrightleds.com ) and LEDSupply - For All Your LED Project Needs!
are some of the better suppliers for LED strip lights and controllers.
It is really tough to find wide temperature range rated LED electronics.
There are some marine LED lighting suppliers, but the prices can give a person pause.
Discussion Starter · #5 ·
2019 T250 LWB EL High Roof 3.5L EcoBoost
I have the Task Lighting RF units referenced by Tcaschy021 above. I went with the 4-zone controllers though. Very happy with the system. Have 3 zones set up and can control them from 3 different places in the van. Pricey yes, but worth it I think.
Reactions: Tcaschy021
Discussion Starter · #9 ·
Sweet! Thanks for chiming in.
I've started to set things up by pairing the controllers to the receiver and so far working pretty good outside the van.
Question for you: If I press the ON button, I'm expecting the lights to turn on at 100% each time but it seems to instead remember the previous level. Is there a way to set it to 100% On each time? Or is there a quick button press combo that automatically goes to 100%?
1 - 9 of 9 Posts
